Using ArcGISPro (2.4) Mosaic process does not work, Blending does not work. My images have Straight lines from the Footprint, and not the Seamlines. Is there a method for incorporating Seamlines to blend or smooth overlapping areas?
1221
12-06-2019 09:24 AM
SWilander
New Contributor III
Arcpro Mosaic process will not output acceptable seamless mosaics.
I have Georeferenced ~400 historical aerial images and want to mosaic the images into a single stand alone .tif file. When I run Mosaic To a New Raster, the output does not utilize the Seamlines I have created. Rather it uses the Footprints to mosaic the images. This leaves straight lines between images (along a flightline).
My workflow is as follows:
Create Mosaic Dataset (the big empty nothing in a file.gdb)
Add Rasters To Mosaic Dataset (Add my Georeferenced aerial images)
Build Footprints
Compute Mosaic Candidates
Build Seamlines (Radiometry)
Mosaic To New Raster
Why wont this process work? Anyone have a similar issue?
Tags (1)
GuenterDoerffel
Steven,
the Seamlines will only be used, if you set the MosaicMethod to 'Seamline' - did you do that (sorry if that is too simple)?
Remember that if you do the export from a Catalog item, the DEFAULT MOSAIC METHOD will be applied, so for that process you'd have to set this to SEAMLINE.
Note a few more comments:
  • If your historic images overlap a lot, you might make use of the VORONOI method to create the Seamlines
  • Whatever Seamline method you used, the blend_width/blend_width_units and blend_type will have an effect
  • In the Seamline FC Attribute Table you can set individual values for those if you like
Regards
Guenter
SWilander
New Contributor III
Thank you Guenter. That's a fine answer. Where specifically do I need to set that process to Seamline? I have done this in Mosaic Dataset Properties, and in Configure Allow List. You are correct I am interfacing in Catalog and only use the Analysis Tools to run the Mosaic To a New Raster. I think you have answered the question, I will have to look around some more. Thank you.
GuenterDoerffel
Steven,
In the MosaicDataset Properties, where you mention the ‘allow list’ there is also the default selection.
To see if it actually does what you want I would start in Pro/Map and check visually ...
- does the Seamline sub-later show up and contain polygons?
- when you use ‘Seamline’ mosaicking there (and zoom in to a Seamline a lot) - do you see the effect?
G.
Sent from mobile Phone
Am 11.12.2019 um 19:12 schrieb Steven Dale <geonet@esri.com<mailto:geonet@esri.com>>:
GeoNet, The Esri Community | GIS and Geospatial Professional Community <https://community.esri.com/?et=watches.email.thread>
Re: Using ArcGISPro (2.4) Mosaic process does not work, Blending does not work. My images have Straight lines from the Footprint, and not the Seamlines. Is there a method for incorporating Seamlines to blend or smooth overlapping areas?
reply from Steven Dale<https://community.esri.com/people/SDale@slco.org_slco?et=watches.email.thread> in Imagery and Remote Sensing - View the full discussion<https://community.esri.com/message/896802-re-using-arcgispro-24-mosaic-process-does-not-work-blending-does-not-work-my-images-have-straight-lines-from-the-footprint-and-not-the-seamlines-is-there-a-method-for-incorporating-seamlines-to-blend-or-smooth-overlapping-areas?commentID=896802&et=watches.email.thread#comment-896802>
SWilander
New Contributor III
Thanks Guenter. The answer in the end was to adjust the properties in the Mosaic Dataset in the TOC of the Map (Specifically), and I was able to reach the correct output -of using the Seamlines in the Mosaic process.
