I can successfully run the OptimizeRasters script within it's 'Pro Toolbox' but running the script from the command line (python.exe accessible prompt) it fails with the messages:
log-critical:No module named azure.storage.blob
log-critical:Unable to initialize the (Azure) upload module! Check module setup/credentials. Quitting..
log-status:[Failed!]
I have 'pip-installed' (for
c:\Python27
) and 'conda installed' (for arcgispro-py3
) the azure package and even done it for azure-storage-blob but cannot make progress and receive the same error.
NOTE: I took the command parameters from the successful toolbox run of the script in here:
C:\Image_Mgmt_Workflows\OptimizeRasters\logs
and this line in the XML:
<Cmd-line>
<Message>-config=C:/Image_Mgmt_Workflows/OptimizeRasters/UserTemplates/Imagery_to_MRF_JPEG_20191214160457.xml -output=imagery -tempoutput=C:\temp -input=D:\client_imagery\input_image -cloudupload=true -outputprofile=client_azure_storage -clouduploadtype=azure -outputbucket=arcgis -cache=D:\client_imagery\imagery_cache -rasterproxypath=D:\client_imagery\raster_proxies
<Duration>0</Duration>
</Cmd-line>
What might be the cause?
