I am seeking an imagery that I need for my project for a hydrologist . It needs to have a color that can overlaps in between 60% and 40%.
I need to be the most recently up to today and my plan was to build a point cloud done in a Agisoft Metashape.
I have create a survey area in Google Earth here but I do not know if you can see it or not..
Google Earth :
ArcGIS Online :
Please do let me know if that doesn't work.
Hi PROBERT68,
Have you had a look at the USGS EarthExplorer application? (link: https://earthexplorer.usgs.gov/)
There main be some existing and publicly available True Colour imagery via a UAS, Aerial or Sentinel-2 Satellite.
Do note, that a sparse point cloud built in AgiSoft requires the flight information and several images from the mission. For your coverage, your overlap may not be publicly available.
Good Luck!
I have been to that site all the time and did not find any.
Another available resource is The ESA. Here's a link to their open data access hub: https://scihub.copernicus.eu/dhus/#/home . Again, RGB imagery is available via the Sentinel-2 mission.
If you are looking for more post-processed APIs, then you can look into one of their web services. Here's a link to Sentinel Hub by Sinergise https://www.sentinel-hub.com/explore/sentinelplayground/
I do not see any 9x9 color frames for aerial photography on that site ?
FYI, the LIDAR was all I need from this site Colorado Hazard Mapping.
https://coloradohazardmapping.com/
P.S. For those you need from Colorado wanted to download, be prepare for a Large file size !!
Even if you send them the shapefile for a small area....
