Seamless, color balanced mosaic dataset
598
9
10-16-2020 08:58 AM
Sheen_EiseleLenon
I am trying to color balance the rasters inside my mosaic dataset (in an ArcGIS Pro environment) to create a seamless output. However, I am having difficulty in doing so. Is there a documentation I can refer to? Or some tips and tricks? Thanks.
Reply
Robert_LeClair
Esri Frequent Contributor
Sheen - have you tried the Color Balance Mosaic Dataset GP tool in the Data Management Toolset?  What is the result?
Reply
Sheen_EiseleLenon
Hi Robert. Yeah, I have tried that and the result is awful. I'm currently testing with just two images.
Reply
Robert_LeClair
Hmm...we're all the prerequisites mentioned in the tool webpage true with your images?
Reply
Sheen_EiseleLenon
Yes to all the prerequisites.
I'm trying to color balance images taken from different date of captures.
Reply
PeterBecker
Can you provide some samples. It may be due to you not masking out extreme colors.
Reply
Sheen_EiseleLenon
Hi Peter,
Here's how the mosaic looks like. The highlighted line is my seamline.
Here
Here's the mosaic when the seamline is unchecked:Mosaic - when the seamline is unchecked
The mosaic looks ok.
- Blend width: 50
- Blend type: both
However, when I export the mosaic, the image looks like this: Exported mosaic
Any suggestions on how I can improve this? Thanks!
Reply
PeterBecker
Looks like there is a significant difference in the contrasts enhancement of the two images and they appear to be taken on very different dates. Visually the results can be improved by reducing the contrast (stretch), but they might also loose details. Check the stretch being applied before color correction. This could improve it a bit. It also looks like the blend parameter is missing from the export. Check that 'resolve overlap' is set to blend before export.
Reply
Sheen_EiseleLenon
Hi Peter,
Yes the images were taken on different dates. I'm trying to mosaic them to patch for the cloud cover on one of the images.
Where can I see the resolve overlap before exporting the image? Thanks!
Reply
Sheen_EiseleLenon
Hi Peter,
Found the resolve overlap setting.   I will try and see if there will be changes in my mosaic. Thanks again.
Reply
