Publish mosaic dataset as map service
3747
10-07-2020 11:24 AM
SoratoSouza_e_Silva
Occasional Contributor II
How can I publish a mosaic dataset as a map service, without using an Image Server license?
Thank´s
Arcgis Server 10.8
by Anonymous User
Not applicable
Hi Sorato,
In order to publish a mosaic dataset as a map service, you need to have an ArcGIS Server site licensed with the Image Server role.
As a workaround, you could export the mosaic dataset to a single raster dataset using the Mosaic to New Raster tool: Mosaic To New Raster (Data Management)—ArcGIS Pro | Documentation
This way, you are publishing a single raster dataset as a map service, which does not require an additional license for ArcGIS Server.
Hope this helps!
-Calvin
by Anonymous User
Not applicable
Hi Sorato,
Hope this helps!
-Calvin
SoratoSouza_e_Silva
Thank you very much for your guidance.
I have a doubt, my images are more than 2.5 TB, is it possible to publish? Is there a limit to publishing as a map service?
GuenterDoerffel
Hey Sorato,
publishing 2.5 TB of Data through properly structured MosaicDatasets/ImageServices is not a problem as such. (Just an example: The Sentinel-2 Service from the Living Atlas is a MosaicDataset with 4 Mio records, so referencing 4 Mio Sentinel-2 scenes with 0.5 to 1 GB each, updated every night). The performance will mainly be defined by the data structure of your Images and the storage access speed (storage/network) available. If you have never dealt with those topics, you will find good guidance in the help system and even more so in the ArcGIS Imagery Workflows | Documentation. There is a What are Imagery Best Practices?—Imagery Workflows | Documentation  section about formats and organization. You might also contact your local Distributor for assistance.
Regards
Guenter
PeterBecker
Note that if your imagery just natural color images and you don't need any of the dynamic feature of an image service (IE you are just looking for the image as a background image in webmap) then you can create the mosaic dataset and just convert it to tile cache and publish it directly to ArcGIS Online. See (Serving Cached imagery). No Image server is required for this, it can be done directly in ArcGIS Pro.
KyttMacManus
New Contributor II
We have a similar use case of wanting to publish data stored in a mosaic dataset as a Map Image Service.  We have both a GIS Server and an Image Server federated in our Portal, and it is clear how we could publish an Image Service from these data, but why not a Map Image Service?  The underlying data is too large to support a single file mosaic.  Thanks for any advice?
