Ortho Mapping ArcPro 2.4.1 Parallel instance number
660
10-03-2019 07:08 PM
LanNguyen1
New Contributor III
Hi All,
ArcPro 2.4.1 on a 4 cores server, 12GB RAM (server). For some reason, the Adjustment process just used  2 parallel instances instead of 4.
I tried to reset the parallel processing factor to 100% by
import arcpy
arcpy.env.parallelProcessingFactor = "100%"
However, nothing changed. it took 50mins to finish the job
With the same project on my laptop, I got 4 parallel instances on 4 cores 8GB Ram laptop and took 33 mins to finish the job.
Do you have any idea how to force ArcPro to use more resource?
HongXu
by Esri Contributor
you can set the parallel processing factor from the GP environment setting. Click Analysis->Environments-Parallel Processing
LanNguyen1
New Contributor III
Hi there,
I have set the factor to 100% from the GUI as well as from python since last week but I still get 2 instances only. I suspected that the VM actually allocated only half of the cores for my session. Thank you and will share with you!
