Hi - I'm using the WAB Oriented Imagery Tools and when looking at the coverage graphic in the map, when my 360 is approx level (0 pitch) the coverage area appears to be incorrect, clipped further then an the image centre than it should be.
If I tilt the 360 viewer down by approx 40° then the coverage polygon appears as I believe it should in the first instance.
When viewed in the Pro the coverage area is correct when there view is level no pitch (lowest screen capture).
I have accurate pitch values, approx 90° for all images.
I'm wondering is the elevation service in AGOl affecting the camera height in anyway ? or is the WAB OIC widget calcing the coverage incorrectly? or something else?
Hard to answer this from details provided. Not sure if you have defined a DTM or are using average height above ground. Is it possible that you AvgHtAboveGround is set too large. From the image I would expect about 2.5m. That would be one explanation of why when you are looking directly forward the bottom of the view appears further away. Also check the that HFOV=360 and VFOV=180. (Possibly you have VFOV=90?)
Hi Peter,
thanks for the reply and apologies for the rushed original email and lack of details. I'll provide a bit more info below about the collection and processed images
The confusing part, to me, is why the coverage polygons look correct when using the published OIC in Pro (screenshot 3) . But using the exact same published OIC in a 2D web map with the WAB widgets (July release) the coverage polygon appears truncated (screenshot 1).
Only when tilting the 360 image down 40° does the base extend to the exposure point of the image (screenshot 2).
This suggests to me the elevation of the image used in the web map is higher than it really is?
I'm not sure what the affect of the DEM assigned (or not) when adding images to the OIC is and whether may affect things, but again why would it be different in Pro to the AGOL web map?
Dave
Agreed it is strange. The values in the OIC appear to be correct, else the location point on the road would be wrong. Looks more as if the ImageryViewer is not reading the view angle correct.
I just realized that the viewer you are using looks very old.
Please use the following instead:
2D app : https://oi1.img.arcgis.com/app/index.html
3D app : https://oi1.img.arcgis.com/app3D/index.html
Lets see if this fixes it.
_Peter
Hi Peter - yes using that app seems to make things appear as expected.
But, is this not a custom app?
I was using the latest WAB OIC widget from the Git page, which looks to have been updated in July.
This WAB widget viewer seems to have a couple of extra tools than than the one from the link above, i.e. the measurement tool. Which made me think the WAB tools were more recent?
We create most of our apps using WAB, so would be good if there's a way to log this as an issue to be updated so we can continue to use it. or get access to a newer widget if i was using an outdated one?
Dave
