I have updated to ArcGIS Pro 2.8, however, I'm having troubles with the Oriented Imagery Add-In.
Although I installed the newest release (2.6.1) which should support 2.8, I get the following error message when creating a new OIC
File "<string>", line 242, in execute
File "<string>", line 118, in logParameters
File "C:\Image_Mgmt_Workflows\OrientedImagery\Scripts\SolutionsLog\logger.py", line 149, in Message
print (_message) # if a client side msgCallback has been set.
ValueError: embedded null character
Downgrade the pro 2.8 to 2.7 and test once.
Well, could do, but actually I want to avoid this step... So, I'm seeking for another solution
Hi Marco,
So it looks this error message is the one we tried to fix in the GPTool. Are you sure you have the latest version from arcgis.com. If not do check again. https://www.arcgis.com/home/item.html?id=36ee0bbedca64a5a8b68d7c69ab51728
This error message has nothing to do with the Addin. It has to do with authoring an OIC. Please check that you have the latest GPTool.
