Mosaic Image Service Missing Image
3020
06-29-2011 02:37 PM
DanGriffin
New Contributor III
Hi, I'm trying to publish a .MXD that contains a Mosaic Image. However, I'm getting a data connection error?  The vector layers appear in the Service but no image.
I'm able to publish the Mosaic directly from SDE to an Image Service but not if the Mosaic is within a .MXD?
The SOC account has access to image directory.
Can anyone help?
PatrickWard1
Are you adding the Mosaic Dataset to the MXD and then publishing as a map service or are you publishing the Mosaic Dataset as an image service, adding the image service to the MXD, then publishing it as a map service?
DanGriffin
New Contributor III
I'm adding the Mosaic Dataset to the MXD and then publishing the MXD as a map service
PatrickWard1
Does the ArcGISSOC user account have read access to the Mosaic Dataset and the individual rasters that participate in the Mosaic Dataset?
JeffreySwain
Do you have the Image Server Extension?  Without the extension, you will not be able to publish the mosaic dataset in the mxd.  If you have the extension, be sure that you are using UNC paths and that the SOC has explicit permission to access the source rasters and overviews.
