Modify mosaic dataset 'NoData' black background
1265
03-11-2019 03:43 PM
SamyBouma_Ngock
Problem:
I used to build mosaic datasets (MDs) in Desktop 10.3 and have the NoData background managed as transparent by/within the MD.
I recently upgraded to 10.6 and all the MDs have now the NoData background blackened.
Action:
- reprocessed the MDs using arctoolbox MD tools (i.e. build footprints, calculate statistics, etc.): failed
- recreated a new MD with original images and properties definition: failed
- did a bit of search online, but not conclusive as why although it is my understanding that a mask is usually created with the MD to manage NoData value
- Most of accessible info point to how to symbolize raster nodata/background value which does not help my case since Symbology>Display Background Value>Display NoData as 'No Color' leaves boundary pixels visible...
Questions:
Is this a bug in 10.6?
If not a bug, is the MD imagery workflow different in 10.6 than in 10.3?
How to get the background transparent again from within the MD for my map products?
Thank you
Samy
GuenterDoerffel
Hi Samy,
there was a known issue with JPEG-compressed image display and NoData. A Patch for 10.6.1 (hope this is what you installed?) was released to solve that:
See here: Esri Support ArcMap 10.6 (10.6.1)
You should use 10.6.1 anyway. And if you dont have the option to use 10.6.1, changing the display setting for the data from jpeg-compressed to lets say LZW will also solve the issue.
Regards
Guenter
DanPatterson_Retired
MVP Esteemed Contributor
SamyBouma_Ngock
Thanks for you assistance Dan.
GuenterDoerffel
Hi Samy,
Regards
Guenter
SamyBouma_Ngock
Right on Guenter.
I did install 10.6.1 but seemingly missing the JPEG NoData patch.
In the meantime, I use LZ77 or LERC compression method to get the NoData background transparent.
Thanks
Samy
