Maintaining decimals in a raster and building a raster attribute table
3903
06-12-2015 02:25 PM
PhilC_
I have a population dataset raster I created from a point to raster conversion.   I need to run some analysis on it and need a raster attribute table. I would also like to keep the accuracy of my data, as it contains decimals.
I understand that I cannot create a raster attribute table with a 32 bit floating point raster.  I tried a work around by multiplying by 100 to get integers (while maintaining my true numbers), however, I keep on getting errors in my raster calculator:
File "<string>", line 8, in rcexec
AttributeError: 'str' object has no attribute 'save'
Failed to execute (RasterCalculator).
This has been a wall.  Any help with building a raster attribute table with decimals and/or fixing this error in raster calculator?  Note: I cannot simply use the integer tool as I lose too much information.
Phil
(Not a primary GIS person)
DanPatterson_Retired
lets see you raster calculator expression
alternate, use the multiply tool, then the int tool then deal with the decimal placement once you get it...may have to export the table though
