LAS Dataset to Raster creates raster area way outside LIDAR extent
308
01-07-2021 08:29 AM
DavidBondy1
Hi all,
I'm generating a DEM using the LAS Dataset to Raster tool. The output creates cells for a large area that is outside the LAS dataset extent. You can see this below. The black area is the output raster and the red squares are the LAS dataset extent.
Does anyone know if this is typical or am I setting the parameters incorrectly?
DanPatterson
MVP Notable Contributor
LAS Dataset To Raster (Conversion)—ArcGIS Pro | Documentation
Including a study area boundary as a clip constraint in the definition of the input LAS dataset is highly recommended. One reason is to prevent interpolation from occurring outside the real data extent of the survey. Secondly, there can be a severe performance penalty when using natural neighbor options if the data area is not properly defined.
Do you have one?
... sort of retired...
DavidBondy1
I believe so. I specified the Processing Extent for the tool in the environments section. When I run the tool, it doesn't seem to honour it.
DanPatterson
@DavidBondy1 I am not sure if each red square in an "extent", which is obviously different than their combined "extent".  This would obviously make a difference
DavidBondy1
I had a different polygon that i was using as the study area/LAS extent. I figured out the problem though. I was setting the Processing Extent in Environments as the study area when I should have been setting it in the surface constraints in the LAS dataset itself. Hopefully that resolves the issue. Thanks for the responses!
