I've built a countywide LAS Dataset that feeds a mosaic dataset and an image service. There are no coverage gaps in the LAS Dataset but a strip of NoData is showing up in the mosaic dataset at scales larger than 1:10,000 or so. I figured that meant an overview had the strip of NoData, but the preview from the mosaic dataset shows the LAS Dataset as the problem. The attached graphic shows the selected LAS Dataset and its preview showing the strip of NoData. I'm not sure what's going on here since a LAS Dataset is points, not an image like an overview. Does anyone know how I can
fix this? Thanks.
