JPEG 2000 format is not visible on SOME extents at SOME scales in ArcMap
1356
10-08-2017 07:05 PM
MarkMindlin
We have an issue with one of rasters of *.jp2 format
It is not visible on some extents at some scales.
How to reproduce:
- In ArcMap 10.3.1(10.5.1), add the raster file
- Zoom to some extent
- At zoom of level 17-20, pan around until the raster disappears
The extent does not appear in ArcMap and does not appear on image cache for a map service.
Please help.
DanPatterson_Retired
What is the source location of the image? an image service? If so see
http://desktop.arcgis.com/en/arcmap/latest/map/web-maps-and-services/about-adding-an-image-service-l...
The only other information deals with managing caches
http://desktop.arcgis.com/en/arcmap/latest/map/working-with-arcmap/managing-your-local-display-cache...
especially if no other raster format exhibits this behaviour. (jp2 uses different compression http://desktop.arcgis.com/en/arcmap/latest/tools/environments/compression.htm)
See if a tiff export of the same file behaves the same
MarkMindlin
Dan,
Thank you for your response. The source location is a file system.
We cannot change the workflow.
I do not understand what is wrong with the jpeg 2000 file. Could we recalculate pyramids ?
I would always give it a try first.  Hope that works instead
MarkMindlin
Sorry, please explain what you recommend to try. The size of the JPEG 2000 file is >80 Gb.
