Hi there,
I am currently trying to create an orthomosaic but error occurs. The mosaic dataset has been created, could I rerun the following steps using orthomosaic workspace, I didn't find any button to rerun again. Or the only two solution as below:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
No image for RPC adjustment.
Thanks in advance for helping in any way you can.
Ke Xu
I will help but I need more information. Are you using ArcGIS Pro 2.6.2?
You said the mosaic dataset was created, but this error sounds like it was not complete - am I correct that this error occurred when creating the OM Workspace? And it mentions RPC, so I assume this is satellite data? Was your satellite listed under Sensor Type?
Cody B.
