How to remove shadow in drone imagery?
6583
12-19-2016 11:48 AM
KushendraShah1
New Contributor III
I need to calculate ndvi from infra-red imagery. I have ortho-mosaicked the imagery and wanted to remove the shadow effect of an object in the pixel that is caused by sun angle. Is there way the steps or procedure to correct shadow from ArcGIS software? Any help is appreciated.
CodyBenkelman
Kushendra - there are no specific tools or "magic method" for removing shadows from extremely high resolution imagery within ArcGIS, but our Segmentation tools may be relatively effective at highlighting areas of shadow vs. non shadow, and allowing you to combine shaded areas into their appropriate groundcover class.  (See these links to Help for Pro or ArcMap.  What version are you using?)
However, I think it is worth expanding this to discuss other issues.
First, what resolution is your imagery?  I'm assuming centimeters, but if you are flying high and capturing ~1 meter data, the workflow may be somewhat different.
Second and critically important, what sensor are you using?  If it is a Bayer array (single CCD sensor), the spectral content of the red band includes NIR energy that cannot be completely removed, so your NDVI values will be questionable.  If you are using a multi-sensor camera like frpm Micasense, TetraCam, or a hyperspectral imager (e.g. from Resonon, you should be getting good quality spectral imagery.
Third, how did you create your mosaic?  If you are using a Mosaic Dataset and are rectifying each image "on the fly" into a virtual mosaic, you have not disrupted your original pixel values by resampling.  Otherwise, if you have used Drone2Map, Pix4D, or similar software to create a single orthomosaic, your spectral values have already been modified by both multi-scene averaging and resampling such that an NDVI will be less accurate.  (If you add this onto the Bayer array issue #2, I'd say your NDVI will be qualitative at best - not a highly accurate quantitative measurement).
All together, my experience is that NDVI dramatically reduces the effects of shadow.  Since the shadow diminishes the brightness value of both the NIR and Red bands, the ratio in the NDVI should not show a dramatic difference in shadowed vs. non-shadowed regions.  e.g. you may want to review this paper: "An Analysis of Shadow Effects on Spectral Vegetation Indexes Using a Ground-Based Imaging Spectromet..."
In fact, I have used NDVI specifically for the purpose of compensating for shadow.  If your data seems to show dark shadows in the NDVI, I suspect your sensor is not providing good quality measurements in the two bands.
DanPatterson_Retired
I see no tools specific to this task.  There are image enhancement tools, but nothing that would leave a image useable for ndvi
KushendraShah1
New Contributor III
thank for the info Dan.
CodyBenkelman
KushendraShah1
New Contributor III
Thanks for the great insights Cody. Yes it is the DJI sensor called Sentera Single  NDVI capable sensor with resolution of 5 cm . I orthomosaic in Agisoft photoscan but I don't think I got the correct output as I expected. The orthomosaicked image has some dark patches and especially shadow portion is giving me high ndvi value when I run from the image analysis toolbar. I will check out with segmentation tools and image enhancement tool if it helps to remove shadow stuffs.
