I've tried to use the Mosaic to New Raster tool with no success. It either never finishes or distorts the image. I've let the tool run for 4-5 days with no results. I've also created a mosaic of the images which is about 130 gigs. I've tried it on and off the network. I've tried to adjust the bands, pixel type. Desperate for help! geotiff image#
Darren,
How many tiffs are we talking about here? What's the overall size of all these tiffs? And why do you need one large raster?
It seems like maybe what you're doing is too big for one raster and maybe this should be more of an imager service that is published to the web and utilized in a more tile-like structure.
Also, this thread would likely do better in a place like https://community.esri.com/community/gis/imagery-and-remote-sensing?sr=search&searchId=f924384d-f9e0.... The GeoNet help is for help with the GeoNet.
Thanks for the reply. I'm new to the game. I have about 450 tiffs that are 366 mb each. We had high resolution imagery flown and it was delivered as geotiffs. I will ultimately replace the old imagery service with this new one. I would also like to have one large raster that I can use when making static maps. It sounds like the only way I can have this is creating smaller sized rasters for specific areas. You have helped by making me think about the use of the imagery. I appreciate it.
I would take a look at Image Management Workflows | ArcGIS Resource Center and
Image Management re: mosaic databases.
One limitation with mosaics, if you plan to publish a service with ArcGIS Server from the mosaic, you need Image Server. If you have the extension, you can publish the mosaic.
If you do not have Image Server and you are just trying to create a service, you can create a map service and create a cache.
We are in the process of transitioning to 10.5.1 but currently we have 10.3. Currently we are using a tiled cache on our dashboard interface with the Imagery Extension but I've heard 10.5.1 is slightly different. Which means we would need an imagery server license. My goal now is to create focus areas and build smaller rasters for those areas. Thanks for the help. I've learned a ton so far!
