I have a number of Historic Aerial images georeferenced that I'd like to clip, mosaic and publish for use in ArcGIS online either as a layer or a basemap using ArcGIS Pro 2.3.
The images have a collar and some collar information that can be totally removed. I have a fair amount of ArcGIS online experience but am new to desktop.
Can someone give some advice about how to go about doing this using ArcGIS Pro 2.3?
Are there any advantages to publishing as a basemap vs. a layer?
Are there are ArcGIS Pro training plans that address this product/workflow specifically?
thank you
Solved! Go to Solution.
Based on what you’ve said, I’ll give abbreviated advice
At a high level, there are three primary options, described here only briefly. It sounds like you’re in the first case, and for the benefit of other readers who may see this, I'll describe the two other options afterward:
We’ll be publishing a deeper discussion on this on http://esriurl.com/ImageryWorkflows soon - I will plan to update this post when that is published.
Cody B
Ryan
(I took the liberty of editing your title so that others may find this post - I hope you don't object)
Short answer, yes.
Unfortunately I'm rushed for time today, so I may not be able to answer more fully until tomorrow, but yes you can do this and we can provide a workflow.
My recommendations will depend on how many photos you have, and what accuracy you seek to achieve. If your screenshot shows the entire collection and you do NOT expect high accuracy, the easiest approach is to use the Georeferencing tools. (see Help)
If you have more photos and/or you're seeking high accuracy, you'll use Ortho Mapping (ArcGIS Pro Advanced license required, Pro 2.4 recommended). In that case, the black collars will be critically important, to enable you to find the fiducial marks around the perimeter of the image.
Check back here and I'll provide more information soon
Cody B.
Thanks Cody, I don't mind the title change. I have 38 photos, about 100mb each from USGS Earth Explorer and I've already georeferenced them individually using the georefernce tools.
The primary purpose of using the imagery is to quickly determine if a road was in place at the date the photos were flown. They are also useful for finding re-alignments of the roads so being able to turn them off and on and compare to existing roads today is helpful.
With that in mind I'm guessing roughly +/- 50' or so seems like it would be accurate enough for the intended purposes without being too disorienting to the user when flickering off/on or dimming with transparency and comparing to the roads today.
I'm attaching a screenshot of one of the full images in case it's helpful. Because I have significant overlap in the images and they are all flown on the same day, I don't believe I need any of the collar information including what you see on the right side of the image below which is written on top of the image rather than in the collar. I believe the neighboring images will allow that portion to be clipped out without any loss of imagery. thank you
Cody B
Thank you Cody, I think the first workflow will work for what I'm trying to accomplish. I was able to create the mosaic but I got lost on part 5, "Use Footprint feature Class to clip the black collar" Is that a function in 2.4? I don't have footprints so I suppose I'll need to create one based on the extent of the raster and then modify it (shrink it) to hide the border?
I can wait for further explanation in the published workflow if you are going to go into further detail on those steps. thanks
Ryan
I'm guessing you're not familiar with the Mosaic Dataset - please see link above. (I was not referring to the GP tool "Mosaic To New Raster" - that creates a new raster file where any pixels hidden in the overlap are gone forever)
The Mosaic Dataset is a virtual mosaic, managed in a geodatabase (the images are not in the GDB, just the MD), and the Footprint is a built-in component that defines the extents of each individual raster.
Look for "Build Footprints", use Method = "None" and use the Shrink Distance parameter to reduce the size of the Footprints (units are meters). Then make sure the MD property under Defaults for "Clip to footprint?" is enabled.
Note you can edit them manually but since you have so much overlap you should be able to shrink them by ~500 to 1000 meters (a guess)
Cody
Thank you that worked great!
Cody, any chance you could elaborate on how to go from the Mosaic to ArcGIS online while minimizing credit consumption? I've got about 30 images totalling around 5 gb georeferenced and mosaiced following the steps we discussed above.
Ryan
sorry I couldn't reply sooner; this will be very brief
I'm pretty sure this is correct but I don't have time to test right now. Could you try it and let me know?
(I don't recall if step 3 actually completes the publishing process, or if you have to go to a 4th step, e.g.
4. log into ArcGIS Online, locate the package, and publish...)
This WILL charge you credits for data storage on ArcGIS Online; 1.2 credits/GB/month = $0.12. Presuming your cache is approx. 5 GB this will be $0.60/month - cost doesn't change if 1 million people view it, or nobody. Your concerns over credit usage may be a reference to using ArcGIS Online to create the cache; that does cost credits and surprised some users by consuming more credits than expected - but once ArcGIS Pro (and ArcMap) had the ability to create cache on the desktop (several years ago), in most cases it's less expensive to perform the caching process on your desktop, then upload & publish the cache.
Let me know your results
Cody B
Thanks, i appreciate the response. I'll try it out hopefully this week and report back. The info on credits is really helpful.
