FMV 1.4 - ArcMap 10.6 install fail
1205
5
12-22-2018 06:59 AM
ChristopherDeRolph
New Contributor III
Hello there,
I'm trying to install FMV 1.4 for ArcMap 10.6. I can run the executable install file successfully, but the extension does not appear (even after ArcMap restart) in my Extensions menu, and there is no "ESRI.ArcGIS.Video.FullMotionVideoAddin.esriAddIn" file in the download for the installation. Any help on this would be much appreciated.
Chris
by Anonymous User
Not applicable
Did we check the folder specified in the first window from the exe? When running the .exe file it'll prompt you to enter a folder, the default along the lines of:
  • C:\Users\<username>\Documents\ArcGIS 10.6\FullMotionVideo
On navigating to that folder there should be a few files including the .esriAddIn file that were extracted by the .exe.
If we've run the .exe and there are no files at the target output location, would suggest checking if you have an extraction utility installed, such as 7-Zip. You can download 7-Zip for free at http://www.7-zip.org/
If the exe has run with an extraction utility stored and there are still no output files in the output folder specified then I would suggest logging a case with technical support who may be able to further assist.
Note that you may also need to request the licence if you haven't already obtained it. My understanding is that it is available for those with active maintenance but you will need to request the licence to be assigned to your account. This won't be affecting the extract/install but is another step to be undertaken.
by Anonymous User
Not applicable
Hi Chris,
After running the exe file (FMVv1.4_forArcGISDesktop10.6.x_165150) it will be unzipped to the folder specified by us i.e. C:\Users\<username>\Documents\ArcGIS 10.6\FullMotionVideo
If we navigate to this folder we can then run the add in file from the guide (ESRI.ArcGIS.Video.FullMotionVideoAddin.esriAddIn), Which will prompt an add in installation utility that looks like this:
I've attached the 1.4 install guide for reference.
ChristopherDeRolph
New Contributor III
Hi Chris,
My problem is I don't get the .addin file when I run the exe file.
Chris
by Anonymous User
Not applicable
ChristopherDeRolph
New Contributor III
Thanks Chris! The ...Documents\ArcGIS 10.6\FullMotionVideo folder was where I needed to look to find the addin file. I was able to complete the install. Thanks!
by Anonymous User
Not applicable
Glad to hear we were able to get it working. Can you please mark the post as answered for other users.
