i downloaded (http://www.arcgis.com/home/item.html?id=e6e1f20cb0374d28a6eed24f5c2ff51b )and import the "Sentinel.pyt" script as toolbox in ArcGIS10.3 just like this video did (http://s3.amazonaws.com/ImageManagementWorkflowsTeam/ImageryTeamHowToVideos/Sentinel2_Build_MD.mp4 ).
However, i always got an error when trying to add a new raster to mosaic dataset. below is the log record:
Executing: Sentinel2 "D:\Geek\Hui_Ramdom Choose\ClassValidation.gdb" demoS2 'D:\Geek\OYLX-South Sea & Sentinel' true false false false true
Start Time: Mon Aug 15 17:37:24 2016
Running script Sentinel2...
log-msg: Using template:C:\Program Files (x86)\ArcGIS\Desktop10.3\Sentinel2 ArcGIS/Parameter/Config/sentinel2\GP_S_Sentinel2_MS_10.xml
log-msg: Processing command(s):CM+AF+AR+CV+CC+BF+BB+SP+DO+BO
log-msg: Command:CM->Create a new mosaic dataset.
log-msg: Creating Geodatabase: (D:/Geek/Hui_Ramdom Choose/ClassValidation.gdb)
log-msg: 000258: File geodatabase already exists!
log-msg: Creating source mosaic datasets:
log-msg: demoS2MS_10
log-status: OK
log-msg: Command:AF->Add fields.
log-msg: Adding custom fields:
log-msg: Using mosaic dataset:demoS2MS_10
log-msg: Creating fields:
log-msg: Dataset_ID
log-status: OK
log-msg: Command:AR->Add rasters/data to a mosaic dataset.
log-msg: Adding rasters:
log-msg: Using mosaic dataset/ID:demoS2MS_10/Sentinel2_10
log-msg: Using ART for DEMOS2MS_10: C:\Program Files (x86)\ArcGIS\Desktop10.3\Sentinel2 ArcGIS\Scripts\Base\..\..\parameter\Rastertype\Sentinel2_MS_10.art.xml
log-msg: Adding items..
log-warning: More args supplied than required to function (arcpy.AddRastersToMosaicDataset_management)
log-msg: Calling (arcpy.AddRastersToMosaicDataset_management)
log-critical: ERROR 000622: Failed to execute (Add Rasters To Mosaic Dataset). Parameters are not valid.
ERROR 000628: Cannot set input into parameter raster_type.
log-msg: Status: FAILED
log-msg: No new mosaic dataset item was added for Dataset ID (Sentinel2_10)
log-critical: No new mosaic dataset items added to dataset (demoS2MS_10). Verify the input data path/raster type is correct
log-status: Failed!
log-msg: Done...
Completed script Sentinel2...
Failed to execute (Sentinel2).
Failed at Mon Aug 15 17:37:33 2016 (Elapsed Time: 9.30 seconds)
what is even worse is i can't add a new raster band (neither file nor workspace) manually through build-in tools in data-management.
any help will be appreciated, thks!
Solved! Go to Solution.
Mervyn Lotter told me that this script can only be use in certain version of ArcGIS. Unfortunately, below is my version, which did not embed sentinel2 as a valid raster type.
if you version is 10.3.1 or 10.4 or Pro, Raster Type Cumulative Patch can help.
