Drone2Map Monthly Limits?
230
10-07-2019 11:58 AM
New Contributor II
Hello,
I am trying to find out if Drone2Map has a limit (monthly or annually) for the number of projects and/or images that you can process with a single subscription. For example, I believe Pix4Dmapper has a limit of 10 projects or 2,500 images per month.
Thanks!
-Mike
Tags (1)
Reply
There are no monthly limits.  As of today (Drone2Map version 2.0) the only licensing available is "named user" which must authenticate through ArcGIS Online or ArcGIS Portal, but there are no limits on # of projects or # of images.
At the 2.1 release we will add the "Single Use" license option which will not need to authenticate with a portal.
Cody B
Cody B
New Contributor II
Thanks Cody! This answers my question.
Reply
