Regarding running multiple processing runs in Drone2Map: For processing run #1, I used Drone2Map to generate an ortho, DSM and DTM using the Inverse Distance Weighting method with no noise filtering and no smoothing applied. For the processing run #2, I re-ran the processing using the triangulation algorithm, noise filtering, and surface smoothing ("smooth" option). However, the results of the 2nd run (DSM and DTM) overwrote my original 2D products, including the report, so I can't compare the two.
Is there a way to do multiple processing runs in Drone2Map within the same project while preserving previous results? I could create an entirely new project, but I believe I'd have to re-do the links between photos and GCPs, which I'd rather not have to do.
