Difference in color: mosaic dataset vs web map service
845
10-25-2017 09:45 PM
MarkMindlin
We have published a web map service with a cache which is clearly different in color from source mosaic dataset.
In what direction should we investigate?
Mosaic dataset
Cache
ArcGIS Desktop 10.3.1, ArcGIS Server 10.3.1
The tool is
Manage Tile Cache—Help | ArcGIS for Desktop
It does not contain any color settings.
Any help please.
GünterDörffel
Hi Mark,
whenever display is different - check the stretching-settings first: Converting a MosaicDataset to a cache (dont know wether you did it together with other data from a map document or from the mosaic right away) will apply either the default of the MosaicDataset - even if none or whatever the map document specifies. That could differ.
By the way: The raster team out of redlands has published a nice toolbox to create tile caches from Rasters/Mosaics: See this link: http://www.arcgis.com/home/item.html?id=b66bdaa9cec247c087cc836ada6fe2b1
MarkMindlin
Hi Günter,
Thank you for the response.
Here is the list of parameters
ManageTileCache_management (in_cache_location, manage_mode, {in_cache_name},
{in_datasource}, {tiling_scheme}, {import_tiling_scheme}, {scales}, {area_of_interest},
{max_cell_size}, {min_cached_scale}, {max_cached_scale})
Where is "stretching"?
GünterDörffel
Not in this parameters, but part of your Mosaic settings taking effect when adding it to ArcGIS Pro/ArcMap or any other display. See the help on “Source Type” of a Raster (and a setting in every Mosaic) and its effects …
http://desktop.arcgis.com/en/arcmap/10.3/manage-data/raster-and-images/raster-dataset-properties.htm
Regards
Guenter
Von: Mark Mindlin
Gesendet: Thursday, October 26, 2017 2:34 PM
An: Dörffel Günter <g.doerffel@mysynergis.com>
Betreff: Re: - Re: Difference in color: mosaic dataset vs web map service
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from Mark Mindlin<https://community.esri.com/people/mik1971?et=watches.email.thread> in Imagery and Remote Sensing - View the full discussion<https://community.esri.com/message/724802-re-difference-in-color-mosaic-dataset-vs-web-map-service?commentID=724802&et=watches.email.thread#comment-724802>
MarkMindlin
I was under an impression that should work like
"what I see in ArcMap mosaic dataset        what I get in a cache"
but it is not.
