this is my first post on this forum. I'm new to the concept of Deep Learning and I'm following the lesson "Use Deep Learning to Assess Palm Tree Health". I was able to follow this tutorial without a problem until I got stuck on prepare_data function with the following error:
So I followed the suggestion and tried to install those packages again with the following result:
However that did not help. So I tried to install the latest versions of those packages as following:
That did not help either. So now I'm asking what am I doing wrong ?
My PC specs:
CPU: AMD Ryzen Threadripper 1950X
GPU: NVIDIA GTX 1080 Ti with latest drivers
OS: Win 10 64bit
Latest NVIDIA CUDA Toolkit and cuDNN package installed.
I use ArcGIS Pro 2.4.2 trial
I haven't tested the Deep Learning tools in ArcGIS Pro yet. I suppose I have all necessary HW and SW installed to run either Pytorch or TensorFlow on my GPU but I don't want to do this before this problem is solved. Any possible testing would not make sense anyway without solving this issue. Anyone else got this problem ?
Thanks !
deep_learning #palm_trees prepare_data
Thanks for the suggestion Shaun ! This really helped !
But while executing the python script in jupyter lab I came to another error:
I believe the error produced by the float conversion function has something to do with a comma (,) symbol in the string value. Is it a problem of arcgis python implementation on Windows ? How can I correct this ?
Great!
That looks like a bug in the implementation of the Python API. If you're adventurous, you can try fixing with code like this:
python - How do I parse a string to a float or int? - Stack Overflow
Or (temporarly) change your locale period by using one of the blue countries in this map:
https://upload.wikimedia.org/wikipedia/commons/a/a8/DecimalSeparator.svg
I would also report this issue here:
GitHub - Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python
Shaun
Hello, I have this exact same error. I checked the GitHub and the pytorch tutorial is blank without uploaded code. The tensorflow example from GitHub works, but you must be very careful with the versions installed within python. Thanks for posting this earlier--it's frustrating eh?
I also recreated the python shell from scratch exactly duplicating the tutorial commands. Same result.
I then completed the conda install as suggested in the error message:
OMG--the above clean install and update fixed this particular error! YIPPEE!
Oops, wrong again. The Kernel was not running. Note above in the upper right--the No Kernel notification.
I restarted the Kernel and received the same error as earlier. \
This has the same error using the Python3 kernel. Any help would be greatly appreciated!
I recalculated everything using the exact capitalization used in the on-line tutorial. After reading the documentation for prepare_data I added some other attributes--no change. This is curious. I also switched to jupyter classic so I could Trust the notebook.
Still the same error. It seems that the path is never actually used:
Slight modification--still an error with prepare_data:
This seems like it should work, but fails. Any ideas would be greatly appreciated!
Can you follow these steps to install the framework?
Install deep learning frameworks for ArcGIS—ArcGIS Pro | Documentation
The error message states there's a missing dpeendancy. It could very well also be you have installed the relevant python modules to the new cloned enviornment, but its not your active python environment and hence the failures
