ArcPro 2.6
Using the tools described in the ArcGIS Blog post, new-pretrained-models-at-fedgis/ , I attempted to use the building extraction deep learning model and the road extraction model on a test image. The building extraction model ran without problem. The road extraction model provides an error message as soon as I select the Model Definition file. I am providing a screen capture of the error. Any help? Thanks
Hi Todd,
You need ArcGIS Pro 2.7 for this model to run.
Thanks. That's an easy answer.
