Deep Learning KITTI Labels BUG
578
04-27-2020 12:49 PM
BahramJomehzadeh1
New Contributor III
I've been trying Train Deep Learning Model (in order to building footprint extraction from WorldView 2 image) using exported training data with KITTI Labels meta data format but every time add the output Image Chips folder faced this error.
ERROR 032659 updateParameters Execution Error: Traceback (most recent call last):
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx#TrainDeepLearningModel_ia.UpdateParameters.py", line 4, in <module>
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx#TrainDeepLearningModel_ia.UpdateParameters.py", line 62, in updateParameters
IndexError: list index out of range
Any opinion?
VinayViswambharan
Hey Bahram -
  1. Please use RCNN as the metadata format when exporting your training samples, as you are trying to delineate building footprint (and not just derive bounding polygons around buildings).
  2. Also when running the train deep learning model tool, explicitly, change the model type parameter (it will be blank by default which is causing your error messafe)and that should solve your problem
Regards,
Vinay
BahramJomehzadeh1
New Contributor III
How are you Vinay.
I actually had tried the rest of the models including MaskRCNN - Object detection and unfortunately the best result I've achieved (applying MaskRCNN - Object detection) that is not nothing satisfying!
I was wondering if using KITTI Labels would be better result!?
CaroGru
From what I can see on the second screenshot you provided, your training data are the outlines of the buildings. For MaskRCNN to work better, I would change your training data to polygons (a polygon = a building).
