I tried to create an Image Service and then started. I got the the problem to start it. My procedure is below and the
1) Start ArcCatalog and navigate to the Image layer in the SDE Geodatabase.
2) Right-click the image layer and then click Publish to ArcGIS Server.
3) When the wizard pops out, select the folder created (e.g. Wildlife_Images), and then click Next button.
4) On the next page of the wizard, only Image is checked. Click Next button.
5) Click Finish button.
Then, I received the warning message (see the attachment)
6) Open the ArcGIS Server tree on the Catalog, I could see the image layer in the Wildlife_Images folder.
7) Right-click the image layer and then click Start, the same message shows the failure of the Start.
What is wrong with my procedure here? If you know, please provide help. Thanks.
