Can i change the units in the iOS SiteScan App to Metric?
1061
12-07-2020 02:55 AM
David_Brooks
MVP Regular Contributor
Site Scan LE is a fantastic step in the right direciton for ESRI. My quesiton is, can i set the App units to metric? Everything is in feet and inches, which is a big pain for an EU user!
David
..Maps with no limits..
NicoBonnafoux
Hi Brooks,
The Site Scan Flight app or Site Scan LE use the units defined by your iPad in the Regional Settings.
If you set your Region to a country using the metric system, the App should default to that.
iPad Settings --> General --> Language & Region --> Region --> Select a country using metric units (e.g. United Kingdom).
We'll look into adding a Site Scan setting to override this directly from the app.
NicoBonnafoux
Hi Brooks,
David_Brooks
Spot on, that worked a treat, thank you!
David
