I published an Image Service with WCS capabilities using HTTPS/SSL. The ArcGIS Server connection works fine in ArcMap, but when I connect with the WCS protocol the image does not show up. I can connect, but it fails to display. I noticed that in the connection properties were empty; no metadata for the WCS connection. The ArcGIS Server connection has all the metadata. I'm wondering if this is the issue and how to fix it?
WCS connections work fine with regular HTTP. It is definately the HTTPS/SSL which is the issue.
I am using ArcGIS Server 10 with IIS7 on Windows Server 2008 R2 64bit.
HTTPS/SSL and Windows Authentication is enabled.
Comments are very much appreciated.
Thanks!
