I am working with MODIS 8-day average Land Surface Temperature (LST) raster files. I want to do a raster normalization for each raster in raster calculator. Since I have many raster files I want to create model builder so that I can run them in an iterative system. I am using the following equation.
(MAX(Raster))-(Raster)/(MAX(Raster))-(MIN(Raster))
However the raster calculator displays an error. I have searched for similar cases but I only saw python based solutions. Therefore this is to kindly ask if there is a way to do this without writing python script?
Besides, Model Builder and arcpy script, you can run the Raster Calculator tool in the Batch mode. To do that, just click the tool > click 'Batch'. See web-help document here: https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/basics/batch-geoprocessing.htm
What error the Raster Calculator tool is returning, can you share? I wonder if the size of the images.
ArcGIS Pro is much better at processing large datasets.
