Hello,
I am using ArcMap 10.2.1.
I am learning about how aerial imagery is photographed. I understand there is a "cone" that captures the Instantaneous Field of View. I have also read that the optics are rotating. So I have to ask; does the satellite optics scan a triangular swath that rotates to create the cone of instantaneous view?
Solved! Go to Solution.
Moved to imagery and Remote Sensing
There are remote sensing tutorials on line that will answer these questions.
IFOV (Instantaneous Field of View)
A measure of the spatial resolution of a remote sensing imaging system. Defined as the angle subtended by a single detector element on the axis of the optical system. IFOV has the following attributes:
A esaustive definition and other useful infos here
Principles of Remote Sensing - Centre for Remote Imaging, Sensing and Processing, CRISP
More info here
http://www.utsa.edu/lrsg/Teaching/GEO5053_4093/L2-basics.ppt
here
http://www.uprm.edu/biology/profs/chinea/gis/g06/NRC2_3_2_6.pdf
here
http://www.geo.mtu.edu/rs4hazards/ksdurst/website/lectures/RemoteSensing.pdf
and here
http://gis.humboldt.edu/club/Images/Documents/lecture7.pdf
But if you contine you 'll find another usefull tutorials over the web
