Why can't I set symbology from RGB Composite to Stretched in a raster catalog of what are really B&W tiffs?
772
07-24-2017 05:43 AM
ChuckHorne
I have a set of .tif files that are scanned plots from a series that are basic to the utility operation. The plots are black & white and have been clipped and georeference to make a backdrop. When I was doing this with .png, everything was fine, but now that I tried tif, I notice these effects:
  • every time I add one as a layer, it comes up with these bizarre Jimi-Hendrix-poster looking color scheme
  • if I go to the layer properties, Symbology tab, and switch from RGB Composite to stretched, they become B&W and look just like the original plots
  • I created a raster catalog and loaded the entire set in there, but when I add the raster catalog as a layer, it still comes up with the 60's crazy color scheme, but the Symbology tab doesn't enable changing:
  • I note that while I can choose and Apply Stretched, it doesn't do anything
  • After a hacking period, I observed that I can simply Remove RGB Composite, in which case Stretched becomes the choice and it does work
GünterDörffel
Occasional Contributor III
Chuck, have you got at least "Standard Edition"? Then please use a MosaicDatset instead of a rather old fashioned and much less performing raster catalog ... and we'll figure out whatever need you have 🙂
TIFF is a very "wide-range of content" format. In your case the 1-bit data might be effectively stored as CCIT4 compressed data. At least that would be nice. I assume in your data it is stored as 24 bit - what a waste of ressources 🙂  So I assume you are running into stretching and "automated data recognition issues" - but again - if this is b/w anyway you should convert to 1bit for the raw data and maybe only use some overviews with bilinear interpolation at large scales. SInce you probably can not share a file, we'll have to "discuss" that here ...
I've done a lot with Utility backdrop imagery  ... tons of it ...
Regards Guenter
