Hi all,
I've been trying to figure what metadata is needed to be able to use measurement tools in Oriented Imagery Viewer. I've created an Oriented Imagery catalog from aerial oblique imagery service (https://sampleserver6.arcgisonline.com/arcgis/rest/services/Oblique/WU_Oblique/ImageServer) . Looking at the resulting exposure points - they have CamOri field with detailed camera orientation. I've also used DEM service when I created this catalog. But I'm still unable to use measurement tools with this oriented imagery catalog:
This is the content of the oic:
{"type": "OIC", "version": "2.1", "properties": {"Name": "test8", "Description": "test", "Tags": "OrientedImagery", "ServiceURL": "https://services6.arcgis.com/YtqGNFEdrYd1pjuW/arcgis/rest/services/test8_ExposurePoints/FeatureServer/1", "OverviewURL": "https://tiles.arcgis.com/tiles/YtqGNFEdrYd1pjuW/arcgis/rest/services/test8_CoverageMap/VectorTileServer", "DefaultAttributes": {"CamHeading": "", "CamPitch": "", "CamRoll": "0", "HFOV": "", "VFOV": "", "AvgHtAG": "", "FarDist": "", "NearDist": "", "OIType": "T", "SortOrder": "", "CamOffset": "", "Accuracy": "", "ImgPyramids": "", "DepthImg": "", "ExternalViewer": "", "ImgRot": "", "ImageryType": "Aerial Oblique Camera"}, "About": "", "ImageField": "", "ImagePrefix": "", "VideoPrefix": "", "DepthImagePrefix": "", "SourceImagePrefix": "", "MaxDistance": "", "DEMPrefix": "I||https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer", "Credentials": {"Username": "", "Password": ""}, "Variables": {}, "Filters": {}, "Copyright": {"text": "test", "url": ""}, "PointsSource": "D:\\Temp\\oblique\\oblique\\orient_test\\test8.gdb\\test8_ExposurePoints", "CoverageSource": "D:\\Temp\\oblique\\oblique\\orient_test\\test8.gdb\\test8_CoverageMap"}}
What data is needed for the measurement functions in OI Viewer to be available?
Thank you,
Tadas
Solved! Go to Solution.
There is no idea or what? I just want to explain more cause I don't
understand this issue of DepthImg.
Le mer. 30 sept. 2020 à 10:37, Soukaina MENJEL <soukaina.menjel@gmail.com>
a écrit :
Another question, I see that you make OIType: T, and when I see my
properties I found that it was a B Type.
What's the types of OIC? and is it necessary to make the type T?
Le lun. 28 sept. 2020 à 21:30, Kushagra Patel <geonet@esri.com> a écrit :
>> GeoNet, The Esri Community | GIS and Geospatial Professional Community
>> <https://community.esri.com/?et=watches.email.thread>
>> Re: What metadata is needed to use measurement tools in Oriented Imagery
>> Viewer?
>> reply from Kushagra Patel
>> <https://community.esri.com/people/Kushagra_Patel-esristaff?et=watches.email.thread>
>> in Imagery and Remote Sensing - View the full discussion
>> <https://community.esri.com/message/956057-re-what-metadata-is-needed-to-use-measurement-tools-in-oriented-imagery-viewer?commentID=956057&et=watches.email.thread#comment-956057>
Do you have depth images?
No.
What's the information that can define it?
Viewer?
<https://community.esri.com/message/957588-re-what-metadata-is-needed-to-use-measurement-tools-in-oriented-imagery-viewer?commentID=957588&et=watches.email.thread#comment-957588>
I am sorry but currently we don't provide tools to generate/create depth images. Users usually obtain depth images using stereo camera, triangulation, point cloud, or Lidar data etc.
Thank you.
Ok, so i have bubble images, with XY and ImageDirection, those informations
cannot be sufficient to define DepthImg using another calculate? Or should
have DepthImg information from the source?
Viewer?
<https://community.esri.com/message/957795-re-what-metadata-is-needed-to-use-measurement-tools-in-oriented-imagery-viewer?commentID=957795&et=watches.email.thread#comment-957795>
No, XY and ImageDirection are not sufficient. You cannot calculate DepthImg. It points to a file resource.
"Image" field in the feature class points to the URL of RGB image. Similarly, "DepthImg" field points to the URL of depth image.
More information about depth - Depth map - Wikipedia
What's the content of the file ressources?
Viewer?
<https://community.esri.com/message/957870-re-what-metadata-is-needed-to-use-measurement-tools-in-oriented-imagery-viewer?commentID=957870&et=watches.email.thread#comment-957870>
How can i access street-level imagery from CycloMedia using Oriented Imagery Catalog?
