Tabulate Area Truncates Field Names in ArcGIS Pro
702
01-02-2019 10:29 AM
by Anonymous User
Not applicable
I'm trying to use the Tabulate Area tool in ArcGIS Pro (version 2.2.1) to cross tabulate two rasters: one raster of zones (where value = true crop type) and a second raster is a supervised classification output from ERDAS IMAGINE (containing a field called Class_Names which are the classes).
The attribute table of my supervised classification (i.e. the classes input for the Tabulate Area Tool) looks like:
The tool successfully generates an output table, but it truncates the field names (i.e. my output table should have a field for select values from the Class_Names field of the supervised classification attribute table pictured above-- but the names are cut off and oddly enough start with A_).
How can I create this table without field names being truncated?
Here's a snapshot of my output table:
My code is:
import arcpy
from arcpy import env
from arcpy.sa import *
arcpy.env.workspace = 'Q:/data/IID_T2_2016.gdb'
TabulateArea(in_zone_data = 'iid_t2_2016_bad00', zone_field = 'Value', in_class_data = 'iid_t2_2016_agsup00',  class_field = 'Class_Names', out_table = 'tableTestv4')
For context, here's my overall mission in case there's another route:
I'm trying to replace a workflow previously completed with ERDAS IMAGINE's Summary Report of Matrix tool, which creates a cross-tabulation report comparing the same two rasters: zones (a raster of incorrectly classified crop fields -- with values in this case of the known ground truth crop type ranging from 1-34) against classes (a pixel-scale supervised classification raster -- in this case with a very long signature class name, e.g. 8084-145-5.01-20-9-1). The resultant output table was essentially a frequency table. It broke up the percentage of each zone's total area by each class.
Here's a snap shot of the first few lines for Zone 1 from the ERDAS IMAGINE output:
MichaelVolz
Esteemed Contributor
Do you get the same results if you try the same operation in ArcMap?
by Anonymous User
Not applicable
Thanks Michael, yep I get the same result exactly.
CodyBenkelman
This geoprocessing tool comes from the Spatial Analyst team.
I've forwarded it to them - hoping they can give you a viable workaround.
https://community.esri.com/community/gis/analysis/spatial-analyst
Cody B.
by Anonymous User
Not applicable
Thank you!
curtvprice
MVP Esteemed Contributor
With many legacy file formats, field names are limited in width. Also in ArcGIS everything (including field names) are not valid when they start with a number, so the tool is inserting the A_ to make the field names valid.
I think the easiest solution is to create a new field with simpler field names (<14 characters, start with a letter) and use that instead of the unwieldy values you have in Class_Names.
Validating table and field names in Python—ArcPy Get Started | ArcGIS Desktop
