Saturated raster when exporting (force RGB enabled)
1497
08-04-2020 07:19 AM
TaylorLoper
The original rasters I'm using seem to have their information packed as 256 bands (top image - jj01se.tif). I need to convert that raster to a 3 band (or RGB image) to use ArcGis Pro classification features. The most obvious solution is to export the raster with "Force RGB" enabled. Unfortunately, this causes a number of problems with over saturation and color changes. Is there something obvious I'm missing here? I've been banging my head against the wall on this one for about a week.
HQO Multiband Situation
Any input would be greatly appreciated.
PeterBecker
It appears you have an image that has been converted from RGB to a colormap. This is a process that some companies use as a form of compression. With a colormap it can not be used as input to many analytics functions. What you can do is use Imagery/Raster Function and apply the 'Colormap to RGB' function. This will create a new layer that now acts as an RGB image that can be used for different analysis. It has the advantage that no new image is created
The export raster with 'use renderer' and 'force RGB' on should also work. The apparent changes in intensity you are seeing are not changes in values, but the fact that when you export an image the system computes stats on the image. When you add the image it by defaults stretches the image based on the stats. In the appearance tab set stretch to None to see the original values.
PeterBecker
TaylorLoper
Peter, that is incredibly informative. Thank you for your reply. I tried the 'Colormap to RGB' function and it works exactly as expected. Similarly, setting the default stretch gives me an identical image as the original that I can do classification on.
Again, thank you for answering my question.
