Oriented Imagery Widget on Experience Builder
1306
06-08-2021 03:55 AM
IniobongBenson
I was trying to replicate this Esri demo web for viewing OIC. I installed the Experience Builder using the installation steps on the website. I the started the server and client. Also I had previously download the widget from GitHub and extracted it to the appropriate client folder.
The Oriented Imagery widget is showing on my list of widget when I start the Experience Builder, however, when I add the widget is shows "arcgisPortal is not defined", is this normal and how can this be fixed.
I did create the app on the Enterprise portal and copied the app ID to the experience builder during the log-in.
I tired using Web App Builder but it seem the widget is only available for 3D maps
I am new to using Experience Builder, so any help would be appreciated
kushagra_patel
Which version of Experience Builder (Dev Edition) are you using? If it is 1.4, then this is a known issue and will be fixed in the next release of Oriented Imagery. Can you please try with version 1.3? Widget works in Experience Builder version 1.3 or below.
kushagra_patel
IniobongBenson
Thank you, yes I was using version 1.4. I got version 1.3, tried it and it worked. Thanks.
