Issue importing GeoTIFF to ArcMap (ArcGIS 10.2)
4122
12-06-2014 09:44 AM
JasonSanford2
I created an orthophoto from Agisoft PhotoScan Pro, a photogrammetry processing software. I exported the orthophoto as a GeoTIFF (.TIF, .KML, and .OVR files were output). The TIFF displays properly in PhotoShop (see attached), but but only a small fraction of the TIFF displays in ArcMap (see attached; laid over at DEM [also exported from PhotoScan] to illustrate true extent), and the colors are not accurate. I've also attached the layer properties for the TIFF. Thanks in advance for any input!
larryzhang
jason,
what is the version that you are using? 1.0.0 or higher?
Can you check how big the TIFF is?
Generally, within ArcGIS, the size of all regular TIFF files should be less than 2 GB. (Otherwise, BigTIFF is required, which is not supported in Agisoft PhotoScan Pro 1.0.0.)
