Is there some way to modify the pixel type of a mosaic raster?
180
11-09-2018 10:11 AM
WillyDeng
Hi there,
I'm attempting to run zonal statistics on a mosaiced data-set but I am encountering the following error code:
The input is not within the defined domain. ERROR 000863. Invalid GP data type.
The input data-set is in the double precision type. I've read that the input should be in the integer data type. Is there some way to modify the raster layers?
DanPatterson_Retired
moved to Imagery and Remote Sensing‌ since it is languishing unfound in this place
If you have a floating point (aka, double) raster, then simply take the Int(eger) of it
Int—Help | ArcGIS Desktop
Now for most scenarios, this won't be a big issue, save the decimals get rounded/truncated, but if that is going to be an issue, then you may need to scale the values up by a factor of 10 to retain the decimal scale you need.
(ie data are between 0 and 1.5... you can scale up to 0 and 15 by multiplying Times—Help | ArcGIS Desktop by 10)
You can do your zonal statistics summaries, but you will have to 'undo' the math because of the scaling.... none is necessary if scaling isn't needed.
WillyDeng
Hi Dan,
Thanks for your response!
