Greetings to all members, I was working on integrating the spectral bands of the Landsat 7 visual, which are the bands 2, 3 and 4, but I did not get the true colors of the Earth's surface? Is it possible to provide me with a digital book file or a link for the purpose of knowing how and the importance of each package or layer in the Landsat visuals? Thank you very much
Assistant teacher.Sabah Omar
Solved! Go to Solution.
Landsat 7: Enhanced Thematic Mapper Plus (ETM+)
Eight spectral bands, including a pan and thermal band:
For True Color Composite, you could use band 3, 2 and 1 in the RGB channel.
Bands 4, 3 and 2 are used for getting a standard FCC (False Color Composite) for Landsat 7.
Thank you very much Mr. Jayanta for this valuable and useful information, I wish you all the success and good luck. Regards
