Generate Trend Raster Error
365
05-01-2023 12:28 AM
AmeeraIbrahim
I was trying to do  Predict Using Trend Rater but I keep receiving an error while attempting to Generate a Trend raster which I successfully did before and I even tried on the same set of data I worked on before but failed to do so too.
Attached below is the error I keep receiving using the tool Generate Trend Raster.
Previously, on attempts it would mention the code of the error 99999 just specifying that something unexpected happened and that failed to execute Generate Trend Raster .
Steps followed are as follow:-
  1. NDVI ,NDWI, Climate Data ( Temp, Humidity, Rainfall ) Maps
  2. Suitability Analysis
  3. Create Mosaic Dataset of the Required Data (Successful)
  4. Build Multidimensional Info (Successful)
  5. Generate Trend Raster ( Unsuccessful)
