I'm trying to map my position/path from videos shot with a Garmin VIRB Ultra 30. I'm following the instructions exactly (for ArcMap 10.6 and FMV 1.4), but when I run Video Multiplexer, the tool reports success but only takes one or two seconds and doesn't write any output.
I've attached example files so someone can reproduce this: a video file and metadata file from VIRB Edit, and the Garmin-provided metadata field mapping file). Would love some assistance.
Ethan
sorry for the delay in our response. I ran your data today in 10.6.1, and the processing worked without problems. (It seems odd your heading values don't change although the camera orientation clearly does - however, I'm sure that's not the source of this problem)
Could you please try again, and confirm you don't have any of the input files open (e.g. in a spreadsheet or text editor) when you run the multiplexer? Do you have any other datasets to test? If you continue to get failures, please contact Esri support and they can help find the problem. https://support.esri.com/en/contact-tech-support
Cody B
