FMV for ArcMap versions/issues
3456
23
08-21-2018 09:44 PM
Will
Occasional Contributor II
When trying to install FMV 1.4 Geoprocessing Tools for ArcMap 10.6.1 it says something like "10.6 is required" and fails to install, and I also noticed there is no FMV available under the 10.6.1. downloads at MyEsri.  What is the ETA on FMV compatible for ArcMap 10.6.1 ?  Thanks.
CodyBenkelman
A new FMV build for 10.6.1 is in test at this time - we're expecting to make it available within the next week or two.
Cody B.
TheresaMulroney1
New Contributor II
I've just looked for a difference between 10.6 and 10.6.1 and both are the same (165150 build). Will this build work for both versions?
CodyBenkelman
Yes, confirming FMV add in version 1.4 will work with ArcMap versions 10.6 or 10.6.1.
If you're having trouble with it, please contact Esri Tech Support and open a trouble ticket.
Cody B
LouiseScally
I am also having the same issue with FMV on ARCGIS 10.6.1. Can you confirm the timescale for the rebuild of FMV so that it can be run with 10.6.1?
Louise
Will
I see ArcGIS Desktop 10.7 has now been released.  Should we wait for a 10.7 compatible FMV build, or try to install the 1.4 version for 10.6.1 ?  Thanks!
CodyBenkelman
I verified with the development team that a new version of FMV should be available for ArcMap 10.7 within just a few days.
Cody B.
Will
Any further word on FMV for 10.7?  I haven't seen it show up in the downloads under 10.7 yet.  Thanks!
CodyBenkelman
the build for 10.7 is done, but just going through the release process here inside Esri...  Thanks for checking back.
Cody B.
Will
Hi again
Is there a build for 10.7.1 (?)  There's a build under the 10.7 downloads that says 10.7.X but when I try to install for 10.7.1 it says something like "10.7 is required" (seems like its looking for 10.7 and not 10.7.1).  I do not see a separate build for 10.7.1 currently on My Esri downloads...
Will
