Drone images not stitching, 1 line flight path and all imagery stacked in one place
368
06-03-2021 08:13 AM
JoseCovarrubias
Good Morning:
I am having a problem when I try to stitch images in Drone2map. When I process a 1 line flight path, all imagery ends up  stacked in one place, the flight is over a runway and there is just in South to North flight path, elevation is 50 feet (75 images) and I have processed successfully multipath images but this one for some reason won't work, I tried processing small subsets but I get the same problem.
I would appreciate any comment or suggestion.
GordonSumerling
Hello Jose,
Generally for the Drone2Map engine to work you will need at least two runs of the imagery. This allows the collection of tie points not only in the forward and backward images but also the side images. The side images provide cross geolocation and will orientated the images back at the correct gps location.
Cheers
Gordon
JoseCovarrubias
Gordon:
Thank you so much, that is exactly what I was looking for!
Have a great day
