G'day, I am very new to the world of ArcGIS and would like to set up a deep learning model to automatically detect objects within an image. I have created the necessary chipped images (Using "export training data for deep leaning) for it however when I use "Train Deep Learning Model" and I select it to use my GPU (RTX 2070) it just uses my CPU. I have followed the Guide called: "Deep Learning With ArcGIS Pro Tips and Tricks: Part 1". However when I get to the very end step of using the import torch and fastai command in the python window, no results are shown.
If anyone could help me out that would be fantastic!!
Guide for settting up deep learning
When I go to test that I do not get any results, no "True" or "false" coming up. I thought I installed CUDA correctly.
Hi Stevohu,
I followed the guided steps from the link you mention above, and the results was 'True'.
Another way is using Python notebook, the result also 'true'.
'Shift' + 'Enter' to run the codes
I used Python Notebook and got this result.
So I ran the "Train Deep Learning Model" with the folllowing settings:
Model Type: Single Shot Detector
Zooms: 1.0
Ratios: [1.0, 1.0]
Chip Size: 256
Backbond Model: ResNet-101
Processor Type: GPU
GPU ID: 0
When it started running it maxed out my CPU (i5 9600k @ 5.1ghz) but it was not using my GPU at all
I'm having the exact same problems. Did you ever get it figured out?
Hi @BrennaOlson ,
Have you try to update ArcGIS Pro version?
