Create Oriented Imagery Catalog Tool Failed
405
04-24-2019 08:15 AM
FrancisPolignano
New Contributor II
I'm trying to follow the Oriented Imagery tutorial but keep getting "Error in create oriented imagery catalog" when I try to create an Oriented Imagery Catalog. Not sure what the issue is, does anyone have any ideas? Thanks **Edit
Running ArcGIS Pro 2.3.2
FrancisPolignano
New Contributor II
Hi Randall,
Thanks for the reply. I've managed to resolve this issue.
All I had to do was browse to the .gdb rather than just typing the name of it in.. . I guess it needed the absolute path.
Randall_XavierRebello
Hi Francis,
Can you check the log files. It is located in c:\Image_Mgmt_Workflows\OrientedImagery\logs\
It should start with the name CreateOrientedImageryCatalog_<date>.xml
Is the file geodatabase in a location where you don't have write access?
Randall
FrancisPolignano
New Contributor II
Hi Randall,
Hi Francis,
Thanks for the info. Glad its resolved. I tried to recreate the issue but I never thought just typing the name.
Randal
