I'm currently working on satellite images (Planet images with 4 bands) and I have to apply deep Learning model to classify them. I exported the training datas with the right size of image (3 bands and unsigned 8-bits pixels) and managed to run the Deep Learning models.
However when I try to apply them on my image, The program says it works but the resulting raster is empty : either the statistics are all at 0 or it doesn't calculate them.
I join what I did and the results.
If anyone could explain to me why it doesn't work, I'd be really grateful.
I moved your post to
Imagery and Remote Sensing Questions - Esri Community
where you are more likely to get an interested and informed audience
Thanks a lot. I hope to get an answer.
Hi Forestfairy -
Please check out this thread. They had a similar problem.
Thank you for your answer. I had troubles with my computer so I couldn't check before. I read the thread and I understood that their problem was that the raster didn't have the correct pixel depth.
That's not my case because I converted the raster and had this corrected after troubles with the deep learning training. So I exported my training data with an 8 bits unsigned and 3 bands raster but it still doesn't work. I join an example of what I did to export my training data :
Therefore I still don't know what's wrong with my models and why it doesn't work.
