Receiving Error 000210 when running LAS Dataset To Raster
10852
17
02-21-2019 08:48 AM
DavidHorrocks
I have downloaded an LAS dataset developed by NOAA for an area of Massachusetts. I am trying to convert this into a DEM I can use to make elevation contours. I have filtered the data so that only ground points are showing. Then, when I try to run the LAS Dataset to Raster tool in ArcGIS Pro 2.3, I receive Error 000210: Cannot create output "filepath".
I have looked at the online help for this error and it looks like a data locking or file path issue. I have closed all other software I had open to make sure something else wasn't locking the data. I have restarted ArcGIS Pro to see if this will help. I have tried saving to a test GDB on my desktop, and the issue still persists.
I have included a screenshot of the parameters I'm using for the tool and LAS properties below. Please let me know if there is a solution to this problem.
Kind regards,
David
DavidHorrocks
Hi Guenter,
I have included screenshots of my tool settings and my LAS dataset properties now.
Regards,
David
VinayViswambharan
Do you have your data in GCS and specified the cellsize of 2. It’s a highly inappropriate cellsize for the data. Assuming this is the problem I’d recommend the las file be projected first (e.g., via the ExtractLAS tool – by setting the output SR in the GP environment for the tool.
DavidHorrocks
Hi Vinay,
Thanks for your response. I first used Extract LAS to convert the LAS file to NAD 1983 UTM and now it will convert to a raster.
David
GuenterDoerffel
Thats the advantage of a global company - one goes to sleep - another one takes over: Thanks Vinay and I am glad you solved it!
MarcoTorres1
Amazing! I had the same problem and it worked!
Can you please place an enhancement and have the error message display something more descriptive.
For example, LASD must be projected in a PCS?
-Marco
AndileMposula
The reason you get this error is because your input is a las file data type instead of las dataset. Use your las file to create las dataset and all should work.
AndileMposula
And don't forget to suffix with ".tif" when naming output.
sandipriz
Hi David,
Thanks for this post as I was having trouble converting raster from .las file.
As suggested, I tried to export the .las file with projection but it throws an error again.
Any suggestion would be helpful.
