Mosaic Dataset - rasters disappear when footprint attribute is edited
10726
11
11-30-2015 07:49 AM
BrianHovis
I am georeferencing Sanborn fire insurance map sheets in a mosaic database using ArcMap.  I had the typical problem of seeing only a green wire frame after adding rasters.  I edited the MaxPS and MinPS as has been recommended in the forums.  I have done this before and it usually fixes the problem.  Something new happened this time, for which I don't have a solution.  I hope someone out there can help.
When I edited the Max PS and Min PS on the footprint attribute table of the mosaic database, the rasters became visible as usual, but when I saved the edits, some rasters disappear.  Any ideas?
BrianHovis
Dear Mark,
Thank you very much for this added information.  I have learned a lot from this group about working with images.  I need to go back and better understand columns, rows, and other parameters.  I have mostly just done what seemed to work, until it doesn't.
BrianHovis
I noticed some folks are still looking at this post.  With the good help of all above, the project was completed.  The results can be seen on the Olympia Historical Society and Bigelow House Museum/Research/Sanborn Maps.  Here is a direct link: https://olympiahistory.org/the-sanborn-overlays/
