I am georeferencing Sanborn fire insurance map sheets in a mosaic database using ArcMap. I had the typical problem of seeing only a green wire frame after adding rasters. I edited the MaxPS and MinPS as has been recommended in the forums. I have done this before and it usually fixes the problem. Something new happened this time, for which I don't have a solution. I hope someone out there can help.
When I edited the Max PS and Min PS on the footprint attribute table of the mosaic database, the rasters became visible as usual, but when I saved the edits, some rasters disappear. Any ideas?
Dear Mark,
Thank you very much for this added information. I have learned a lot from this group about working with images. I need to go back and better understand columns, rows, and other parameters. I have mostly just done what seemed to work, until it doesn't.
