MDCS removing $ in file
850
09-07-2025 07:10 PM
Labels (2)
JamesHead-Mears1
I have a completed MDCS XML file that I am looking to run. However, I have run into an issue running this script as the filepath to the imagery has a $ in the pathname. I've noticed that any of these figures in the XML file are removed during runtime.
I couldn't see anything in the documentation about how the running code deals with this symbol outside of it using it to mark an internal variable as eg: $(variable)$.
Tags (1)
JamesHead-Mears1
MDCS utilises an underlying powershell to run python.exe. Powershell uses $ as a parameter input as such it requires the following to bypass it:
JamesHead-Mears1
